New Member AndyM1969 Posted February 11, 2019 New Member Report Share Posted February 11, 2019 I am having a major problem where materials applied to objects do not appear as they should. I have attached a screengrab with an example, this is a sphere with a gold smart material applied to it, as you can see it appears flat with no surface properties. This is in both DX & GL versions of 3D Coat. Any assistance would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Member Shelton Posted February 11, 2019 Member Report Share Posted February 11, 2019 (edited) You need to enable the glossiness in paint mode. Its the little ball at the top next to your green ball at the top. The three are depth, opacity, and glossiness. You can see in your picture that the glossiness has a X over it. That signifies that it is not being used when you paint or apply the texture. It's the little area in pink in my attached picture. Edited February 11, 2019 by Shelton Adding a picture that shows the area with the glossiness icon Quote Link to comment Share on other sites More sharing options...
New Member AndyM1969 Posted February 11, 2019 Author New Member Report Share Posted February 11, 2019 Thanks Shelton, I did a reset and then someone else pointed that out to me. Thanks Quote Link to comment Share on other sites More sharing options...
