Applink Developer haikalle Posted February 6, 2010 Applink Developer Report Share Posted February 6, 2010 I know that this is only Beta but I just want give ideas to Andrew. Ptex local resolution is nice. It would be nice if you can group those faces and then later if you want to increase or decrease resolution with same faces you could do that with easy. Also options like -> "Bring the resolution the higest" would check the higest resolution from the selected faces and then change that resolution to all selected faces. And also "Bring the resolution to lowest" Quote Link to comment Share on other sites More sharing options...
Advanced Member rimasson Posted February 6, 2010 Advanced Member Report Share Posted February 6, 2010 I know that this is only Beta but I just want give ideas to Andrew. Ptex local resolution is nice. It would be nice if you can group those faces and then later if you want to increase or decrease resolution with same faces you could do that with easy. Also options like -> "Bring the resolution the higest" would check the higest resolution from the selected faces and then change that resolution to all selected faces. And also "Bring the resolution to lowest" I would like to request the same thing. Quote Link to comment Share on other sites More sharing options...
