Member Haamu Posted February 26, 2010 Member Report Share Posted February 26, 2010 Quite simply a tool that removes everything behind the brush in screen space. Like removing infinitely long cylindrical blocks from the model. You can do this with lasso tools while sphere brush is active, but it's not nearly as fluent as eraser brush would be. Another addition might be a move tool with similar cylindrical effect area. These would make my work so much easier. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted February 26, 2010 Report Share Posted February 26, 2010 How about the Hide tool, then Delete Hidden? http://screencast.com/t/NWEwMTExNTk Quote Link to comment Share on other sites More sharing options...
Member Haamu Posted February 27, 2010 Author Member Report Share Posted February 27, 2010 That works slightly better than sphere tool since you can undo it locally, but it still has the problem that the brush center has to touch the part you want to remove. That means you must gobble it en masse instead of gently skimming the edge. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted February 27, 2010 Report Share Posted February 27, 2010 What about using some of the other tools in the E Panel, like B-Splines? Like this: BTW it's not just the Sphere tool, about half of the tools will cut all the way through. Quote Link to comment Share on other sites More sharing options...
Member Haamu Posted February 27, 2010 Author Member Report Share Posted February 27, 2010 Yeh, I've experimented a bit with just about everything. So far the lasso approach seems smoothest, although splines have some additional use since they are persistent. I just noticed that placing some geometry right behind the object makes the move tool work closer to the way I want (since it catches the cursor), but it's kind of a hassle to manage extra surfaces. Still it's gonna help enormously in some cases where that kind of control is needed. Interestingly, the same trick works in ZBrush as well. I'd still much prefer infinite cylindrical eraser and move brush . Quote Link to comment Share on other sites More sharing options...
