Advanced Member Taurus Posted August 15, 2010 Advanced Member Report Share Posted August 15, 2010 You can subdivide msh now but it subdivides without smoothing, multi subdivision preview is needed to see how mesh will look if subdivided with CatmullClark Quote Link to comment Share on other sites More sharing options...
Advanced Member Roger_K Posted August 15, 2010 Advanced Member Report Share Posted August 15, 2010 Good luck mate, ive been asking for this for quite a long time now. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted August 16, 2010 Report Share Posted August 16, 2010 I believe the subdivide button does use Catmull-Clarke. just click the button a few times to check it out, then when finished hit undo the same number of times. Quote Link to comment Share on other sites More sharing options...
Advanced Member Roger_K Posted August 16, 2010 Advanced Member Report Share Posted August 16, 2010 I believe the subdivide button does use Catmull-Clarke. just click the button a few times to check it out, then when finished hit undo the same number of times. Its flat shaded. Which is useless for quickly previewing a sub d mesh. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted August 16, 2010 Report Share Posted August 16, 2010 Sorry I missed the part about smoothing too some how. It's not perfect but you could use the brush tool with Shift, which smooths out the mesh. Quote Link to comment Share on other sites More sharing options...
Advanced Member Roger_K Posted August 16, 2010 Advanced Member Report Share Posted August 16, 2010 Sorry I missed the part about smoothing too some how. It's not perfect but you could use the brush tool with Shift, which smooths out the mesh. Now im not being clear . What I mean and I presume the OP means is Goraud shading. I usually have to export to silo or max just so i can see the model Goraud shaded with a low gloss material (great for showing smoothing errors.) Quote Link to comment Share on other sites More sharing options...
Member mash Posted August 16, 2010 Member Report Share Posted August 16, 2010 What he means is he wants to be able to hit the "tab" key and get the same results he would get in Modo, Lightwave, Maya Etc. Also it would be nice to be able to set the subdivison surface level and turn on or off the Subdivision cage. http://www.youtube.com/watch#!v=UYzyTT6eP0U&feature=related Quote Link to comment Share on other sites More sharing options...
Advanced Member Taurus Posted August 16, 2010 Author Advanced Member Report Share Posted August 16, 2010 Exactly mash,Topogun has it feature and it's really really useful What is now in 3DC is faceted sub, and smoothing with brush is not a solution because CC is needed for quick preview. Quote Link to comment Share on other sites More sharing options...
