Advanced Member Rich_Art Posted September 26, 2010 Advanced Member Report Share Posted September 26, 2010 Hi All, I want to model an array of objects. See the attached image. I can model this with a curve but I don't get the aligning good. In Cinema4D you can use an Array object for example. Just put the curve in the Array and set the amount of clones and a radius. Is there a similar function in 3DCoat? I tried the search function on the forum but without any luck. If there is no function, then I need to model it in Cinema4D and import it in 3DCoat. Peace, Rich_Art. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted September 26, 2010 Contributor Report Share Posted September 26, 2010 Hi All, I want to model an array of objects. See the attached image. I can model this with a curve but I don't get the aligning good. In Cinema4D you can use an Array object for example. Just put the curve in the Array and set the amount of clones and a radius. Is there a similar function in 3DCoat? I tried the search function on the forum but without any luck. If there is no function, then I need to model it in Cinema4D and import it in 3DCoat. Peace, Rich_Art. Try voxel tool named "Axial".It does radial arrays. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Rich_Art Posted September 26, 2010 Author Advanced Member Report Share Posted September 26, 2010 How stupid that I overlooked that. Thanks for the reply. Peace, Rich_Art. Quote Link to comment Share on other sites More sharing options...
