Frenchy Pilou Posted November 26, 2011 Author Share Posted November 26, 2011 MoI is for NURBS only, so it can only Export polygon meshes, it can't read them back in. Actually Moi can read polygons with this plug (not surface of the polygon but structure of the polygons) Obj23dmWireframe converter Download Obj23dmWireframe converter This enables bringing polygon data in an .obj file into MoI to use as a construction guide. Unzip it to some folder, and then you can run the Obj23dmWireframe.exe program. It will prompt you for the name of an .obj file to read, and after that the name of a .3dm file to create. It will read all the polygon data from the obj file and convert the edges of polygons into line segments, and then write those line segments to the 3dm file. You can then load that 3dm file into MoI and use those line segments to snap on to. Originally posted on the forum here. Quote Link to comment Share on other sites More sharing options...
Frenchy Pilou Posted February 15, 2012 Author Share Posted February 15, 2012 New command Offset Multiple Quote Link to comment Share on other sites More sharing options...
