Advanced Member dimitribastos Posted May 4, 2017 Advanced Member Report Share Posted May 4, 2017 (edited) Hi there! At first, my curvature map was correct. Then, later on the texturing process, I decided to calculate it again in order to evaluate the new depth layers. Now, the curvature map have these thin vertical lines all over the textures. Don't know what happened. If it helps, I used Edit Projections in External Editor some time down the pipeline. Same results on 4.7.27 and .26 Edited May 4, 2017 by dimitribastos Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted May 4, 2017 Reputable Contributor Report Share Posted May 4, 2017 I had this before too at times, no idea what causes it. I also have gotten round black circles over each polygon in the model at times too. This is for AO though and not curvature. If possible send the file through the Help menu directly to support for Andrew or one of the developers to look at. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member dimitribastos Posted May 4, 2017 Author Advanced Member Report Share Posted May 4, 2017 Will do it. Thanks. Hope to share the end result soon. Quote Link to comment Share on other sites More sharing options...
