Showing results for tags 'reset'.
Found 4 results
  1. 3DCoatRocks
    Serious 3D Coat bugs
    Dear Developers, This is my bug experience since 30th November on Steam Version. I do have the file I would like to give you in private: - "Reset Hotkeys" Button in Preferences is actually Reset all settings to default - When you press the "End" key, sometimes "The shortcut is already assigned.." dialogue box shows up. To resolve this, I need to restart 3D Coat and "Redefine" it again. - Reassigning shortcuts breaks that function to which the custom key is assigned --> Curves - The "Apply" button does not work to "Curves" when you assign a shortcut. Sometimes you need to press "Reset Hotkeys" (aka Reset all settings to default) in order for it to work. - The Apply Button sometimes just doesn't work. I cannot "Apply" my curve no matter how much I restart, or Reset Everything. I even saved the Curve and it is not working. Thanks, 3DCoatRocks
  2. lefty3d
    Reset rotation values?
    Hey guys, I'm just playing around with 3D-Coat and try to figure out all relevant features for my workflow. One thing I couldn't find anywere is the ability to rotate the object and save the rotation values to reset them after editing. My intention is to edit reconstructed data from Agisoft Photoscan. Therefore I import a model into 3D-Coat and eliminate all the bad areas using the voxel mode. The problem is that I'm not able to align the model properly in Agisoft Photoscan (Standard) so when I export it, it has really weird scaling and rotation, which is really hard to work with. So I want to temporary align the model and after cleaning up all the bad issues bring it back to Agisoft Photoscan to re-project all textures. That's why I need to leave the rotation of the model as it is. Maybe somebody can give me a hint? Greetings
  3. I haven't had a chance to test the latest beta to see if this is in there or not, but it would be great to be able to have a "Set to Default(s)" for the environment map. I changed it in the last beta and then couldn't figure out how to get back to default. Also, having this setting stay the same every time I open the program can be nice and a pain in the neck. Would be great to offer an option to save with each project AND to have a custom default setting.
  4. How do you reset the spline you've made using the Paint with Curves Tool?
