Showing results for tags 'weird'.
Found 4 results
  1. Hey guys, It's my first time on 3D Coat, and i have a problem when i want to import my mesh in 3d coat, there is dark areas on the mesh: And when i import my normal map on the mesh, there is some weird shapes on this areas: So if you have any idea if the problem come from my mesh or my importation in 3d Coat, let me know. Btw, here is what my mesh look like: For information, i did the retopology on Topogun, not 3D Coat. Thanks.
  2. The problem i have is the following : -I unwrapped my UVs fine -I then baked my normals (with the default shader & name correspondance for baking unchecked as it seemed to cause problem) -Normals are fine in the paint room I tried exporting the object from the retopo room (Export Retopo Object) & from the paint room (Export Object & Textures), and in those 2 cases, i get a weird UVW mapping in C4D : Also, in the Retopo room, i can't move retopo meshes in other UV Sets. I tried with my mesh selected or not in the Retopo room, with the initial object layer selected in the Voxtree or not... Anybody has ideas ?
  3. Hey there Coaters, I am having an odd problem importing a hi poly .fbx into the sculpt room. I import it and as usual hit enter to set the mesh without modifications, then when I switch to the 'build clay' brush, my models normals come up reversed. This is one component of a larger model. All components are built with the same technique within Maya. I had a workmate look over it and try to save it out of Max, yet to no avail, still reversed normals. The only solution I found was to do 'Combine' within Maya. By adding another piece of geo to it, the problem goes away and both meshes have correct normals when imported to the sculpt room. Any ideas why this would be happening? Pics below... Thanks Guats
  4. RichardDoble
    At
    From the album: Richard Doble
    Adventure Time Fan Art
