Carlosan Posted July 21, 2012 Report Share Posted July 21, 2012 A workaround is a bypass of a recognized problem in a system. A workaround is typically a temporary fix that implies that a genuine solution to the problem is needed. Hi all Can i ask if possible if every1 that knows workarounds will to share its here ? Ty in advance and regards. Quote Link to comment Share on other sites More sharing options...
