Member DarkEdge Posted August 11, 2012 Member Report Share Posted August 11, 2012 So if I am in Retopo and have applied Symmetry to current layer, then I find a buggered area so I go back in to do some work but I can't really see, I want to delete half of my mesh and then once I am done apply symmetry to current layer again...how can I delete half of my mesh? Thanks! Quote Link to comment Share on other sites More sharing options...
Javis Posted August 11, 2012 Report Share Posted August 11, 2012 Hi. Easiest way is to turn on orthographic mode, select drag rectangle from the e-panel with the Select tool in polymode, drag select the polys you want to delete, then hit the delete key. Should do the job. EDIT: Forgot to mention, make sure to turn off "ignore backfaces" in the e-panel also. 1 Quote Link to comment Share on other sites More sharing options...
Member DarkEdge Posted August 11, 2012 Author Member Report Share Posted August 11, 2012 Hi, thanks for the reply. I can't find the backface toggle...where is it?? Quote Link to comment Share on other sites More sharing options...
Psmith Posted August 11, 2012 Report Share Posted August 11, 2012 The "Ignore backfaces" toggle is in the "E" panel - (press "E" on the keyboard to get the panel to pop up). Greg Smith Quote Link to comment Share on other sites More sharing options...
