Separate Hidden Part (Not Working)
Vaiktorg
I'm having a problem or difficulty with the "Separate Hidden Part" option. When I hide a piece, with the Surface Hide Tool, and try to make it come back as a separate volume, it wont come back. Not even the dialog box opens. :(
That's a situation where I'd email Andrew directly (Support@3d-coat.com), after uploading the workfile (you can actually save out just a single layer, as 3D Coat work file, by RMB over the layer > Save as .3b file). Sounds like some niggly issues I've noticed lately. "Separate Disconnected Pieces" doesn't always work, either. Only way to rectify it is to send the file to Andrew and let him fix it.
You can upload the workfile to their server, directly from within the app, through the HELP menu. "Send large file to support."
Thing is, its not actually on a work file! I'm still exploring everything, and in every chance i get to try to see if it works, it doesn't!
