New Member Count Vertsalot Posted August 4, 2015 New Member Report Share Posted August 4, 2015 I'm attempting to paint a project in 3D Coat. Actually all the work is done and I just need to export it. Throughout the project I added new objects that I built in an external app. I was careful to ensure that the UVs for each new object fit correctly inside the original object's UV map, but I only imported each new object individually. I now have a total of 6 UV maps in 3D Coat. When I go to export the mesh and textures, the mesh exports correctly and all the UVs converge into a single UV map and work perfectly. However, upon export I get 6 different texture maps, one for each UV map that was in 3D Coat. How to I merge them all inside 3D Coat? Importing a new UV map with everything together doesn't work, it destroys the paint. Same goes for using the Move Select tool in the UV room. I just want a single texture map for each export because I have 10 different textures to export for my purposes, times that by 6 and you get a lot of extra work. Quote Link to comment Share on other sites More sharing options...
Contributor Solution Tony Nemo Posted August 5, 2015 Contributor Solution Report Share Posted August 5, 2015 In Retopo room, you can create a new UV map and select, drag and drop all the parts in new map. I would then delete all the old ones and in the paint room, delete any previous objects. Quote Link to comment Share on other sites More sharing options...
