Advanced Member mocaw Posted November 20, 2008 Advanced Member Report Share Posted November 20, 2008 I'm sure this has been requested before since it's such a standard PS thing, but the ability to clone from one layer to another would be great. I was just using your excellent mirroring parameter for the clone tool and wanted to put more info on another layer, so as to avoid accidentally going over my original work...but alas it is not so! Thanks again for the great program- bought it today as I finally have some time to play with it...and avoid Illustrator for a few hours! Thanks! Gideon Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted November 20, 2008 Report Share Posted November 20, 2008 I'm sure this has been requested before since it's such a standard PS thing, but the ability to clone from one layer to another would be great. I was just using your excellent mirroring parameter for the clone tool and wanted to put more info on another layer, so as to avoid accidentally going over my original work...but alas it is not so!Thanks again for the great program- bought it today as I finally have some time to play with it...and avoid Illustrator for a few hours! Thanks! Gideon There is possibility to clone merged summ of lyers on current layer. If you will make 2 layers visible - source and current, you will be able to clone from one layer to other. But I agree, it must be done... Quote Link to comment Share on other sites More sharing options...
Advanced Member mocaw Posted November 20, 2008 Author Advanced Member Report Share Posted November 20, 2008 There is possibility to clone merged summ of lyers on current layer. If you will make 2 layers visible - source and current, you will be able to clone from one layer to other. But I agree, it must be done... I figured this out RIGHT after posting! I need to start clicking on some radio buttons even if they are not in the PDF help and see what happens! Thanks again for a great program! Is there a user wiki with manual? I know you're busy programing with the strength and determination of 10 people so it might be a good idea to let the wonderful user base do this- I'll look around, I'm sure it's already there! Thanks, Gideon Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted November 21, 2008 Report Share Posted November 21, 2008 I figured this out RIGHT after posting! I need to start clicking on some radio buttons even if they are not in the PDF help and see what happens!Thanks again for a great program! Is there a user wiki with manual? I know you're busy programing with the strength and determination of 10 people so it might be a good idea to let the wonderful user base do this- I'll look around, I'm sure it's already there! Thanks, Gideon Thanks for good idea! We will make WIKI manual soon. At least it will be next task for webmaster. Quote Link to comment Share on other sites More sharing options...
