Advanced Member sculptactive Posted May 9, 2016 Advanced Member Report Share Posted May 9, 2016 Is there a "hide tool" or equivalent in the sculpt room? I have a high poly model. I can switch to the "Sculpt room" in Voxel mode to the "Paint room" and use it there, but when I switch back it has changed to surface mode, which normally would not be a problem, but as the model is so high when I try and go back to voxel mode I get the dreaded "Out of Memory". Everything is fine as long as I can stay in Voxel mode...... Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted May 9, 2016 Contributor Report Share Posted May 9, 2016 In voxel mode, you have VoXRay, Vox Hide and Cell to choose from. Quote Link to comment Share on other sites More sharing options...
Advanced Member sculptactive Posted May 9, 2016 Author Advanced Member Report Share Posted May 9, 2016 In voxel mode, you have VoXRay, Vox Hide and Cell to choose from. Hey Thanks. Cell seems to work best and quicker, but I could not find VoxRay even in the manual? Quote Link to comment Share on other sites More sharing options...
Advanced Member Solution sculptactive Posted May 9, 2016 Author Advanced Member Solution Report Share Posted May 9, 2016 Hey Thanks. Cell seems to work best and quicker, but I could not find VoxRay even in the manual? Arhh sometimes it's hard to "see the wood for the trees". Found VoxRay in the objects section. Thanks for helping... Quote Link to comment Share on other sites More sharing options...
