Advanced Member Marc Wakefield Posted August 16, 2016 Advanced Member Report Share Posted August 16, 2016 Hi guys! I hope you are all fine and dandy. I am not sure if this should be in feature requests or here as it could well be an option / tick box I have missed. Is there a way to turn off vertex welding in the retopo room? I am using the retopo room to alter areas of an existing mesh via "use visible paint object as retopo" to correspond to 3d scanned objects from the sculpt room. It all seems to work really well but some of the vertices are merging when they get too close. I need the vertex number and order to stay the same for this object to work as a morph target. Has anyone else come across this "issue".? Thanks very much in advance. Quote Link to comment Share on other sites More sharing options...
Member ryivhnn Posted August 17, 2016 Member Report Share Posted August 17, 2016 Use the Brush tool and make it tiny? Brush tool just moves without welding and if you need to move vertex by vertex you can make it small enough to just fit one vertex Quote Link to comment Share on other sites More sharing options...
Advanced Member Marc Wakefield Posted August 17, 2016 Author Advanced Member Report Share Posted August 17, 2016 Thanks for the reply. I was using the brush tool. (At least I think I was.) The "problem" seems to have sorted itself out now though. It's all working well and I can't even get the vertices to weld if I try. Maybe I was using a different tool. 8-/ Quote Link to comment Share on other sites More sharing options...
Member ryivhnn Posted August 18, 2016 Member Report Share Posted August 18, 2016 There's "Brush" and there's "Move" in the [Edit Geometry] fieldset. Brush only moves vertices within the brush radius (closer centre get moved more, then kind of decreases proportionally going out), Move will move a vertex or edge or face depending on what you select, and will also weld points if you move one close enough to another one and they're within the brush radius (hence the suggestion to make the Brush radius tiny if you need to use Move which I seem to need to do if autosnap is off). Just to be confusing they look the same and the Move tool uses the Brush radius XD You can tell which one you're using because the Move tool highlights the things it's over with yellow whereas Brush doesn't. Move is on the left, Brush is on the right. Glad your problem fixed itself anyway Quote Link to comment Share on other sites More sharing options...
Member DMG Posted January 9 Member Report Share Posted January 9 (edited) HI, Am resurrecting this old thread because I'm wondering the same thing. I have an object (in the Modeller Room) which has geometry crossing the 'x' centre line, and I'd like to mirror it without any points automatically welding together as I will be adjusting it later. Thoughts..? Cheers **EDIT... I've just discovered 'Mesh: Virtual Mirror Mode'. That seems to do what I need, but it doesn't appear to work in conjunction with Live Smooth, so a subdivided version of the mirrored object isn't visible in the Sculpt Room. Edited January 9 by DMG 1 Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted January 10 Report Share Posted January 10 13 hours ago, DMG said: without any points automatically welding Hello. As a workaround, you can select the edge loop and separate part of the mesh Quote Link to comment Share on other sites More sharing options...
Member DMG Posted January 10 Member Report Share Posted January 10 Hi Oleg, Thanks. that might help in some circumstances. The problem I had yesterday was for a pair of eyes which I wanted mirrored—but with overlap—so I could continue to adjust the separation. This wasn't possible with the points automatically welding every time I stopped moving them. I ended up using virtual mirror to get it about right, then unlinked the subdivided sculpt mesh, before mirroring it in the Sculpt workspace. Cheers Derek Quote Link to comment Share on other sites More sharing options...
Gorbatovsky Posted January 10 Report Share Posted January 10 Perhaps this will help you? SymmetryWelding.mp4 1 1 Quote Link to comment Share on other sites More sharing options...
Member DMG Posted January 11 Member Report Share Posted January 11 Hi Oleg, That looks really promising. I like how if polygons are selected, it seems that only those will snap/weld. I can follow that: Create geometry; apply symmetry; move geometry so it overlaps; each side is still separate parts. I think the last part which is niggling me is that if I have two spheres overlapping (as in my example above), after deselecting it, and then reselecting the polygons, when I try to move it, the parts which are on the 'wrong' side of the symmetry line don't translate the same as those on the 'right' side of the symmetry line. I have to turn off symmetry to adjust the position, but obviously, this is only going to affect one side. But this seems to be the normal behaviour for geometry which crosses over the plane of symmetry. Not perfect, but close enough to call a solution. Thank you. Quote Link to comment Share on other sites More sharing options...
