New Member dnhart13 Posted June 7, 2017 New Member Report Share Posted June 7, 2017 Hi... its day-3 for me trial on 3dcoat... just done sculpting and still do retopology for now... theres some trouble i cant find an answer. when you do retopo with symmetry ON.. 1. can you completely turn OFF mid snapping ? in some casses you just dont need snapping... like overlap cartoon eyes 2. flip object on 3dcoat 3. bridge between 2 edges Thanks b4 Quote Link to comment Share on other sites More sharing options...
Javis Posted June 7, 2017 Report Share Posted June 7, 2017 Hi and welcome! 1. Yes. There is a snapping tolerance on the top bar of the application. You could also turn symmetry off when you get close to these areas. 2. More information is needed to properly answer your question. Could you explain more detail what you're needing? 3. The easiest way to bridge to edges is with the "Quads" tool, which has a bridge equivalent preset in the top bar , there is a drop down list called "Edge Extrusion Method", change this to "Parallel". Then click one of the edges you want to bridge, then click the second edge. 1 Quote Link to comment Share on other sites More sharing options...
