3D Coat Forums
davbach
[Bug] Sculpt Paint layers blend as Multiply2 not getting baked
Hi!
I have an issue here with two paint layers which are not getting baked.
Workflow is like this:
Did some vertexpainting on a sculpted model and retopoed it in the retopo room. Then some UV unwrapping.
After this I export the retopo mesh to the paint room with "Bake /w Normal Map (Per Pixel)".
Everything looks good on the paint objects after this, except two layers which are not being baked. Strangely those layers are set to "Modulate2x" as blending mode... but even after switching them to "Standard Blend" the problem exists (and after exporting again froom retopo room the layers switched back to Modulate2x!).
Any ideas why these two layers are being ignored during the baking process?
Cheers,
David
Hi
Are you using latest version 4.8.32 ?
May be is the old Ambient occlusion bake that now is deprecated ?
Yes, I am using 4.8.32.
But how comes that those layers are set to Modulate2x? I am 99% sure that I didn't change this setting. Maybe this is causing the trouble?
Ok, I have no ideas anymore. After trying different (a lot!) things over the past two hours I am giving up...
I even deleted the painted layers and created new ones and the same problem started over again! After baking the new layers switched to Modulate2x and are missing the color-information from the voxelpaint. Maybe it is related to the voxel-layers I am painting on? Or the retopos?
Is there anything I can change which is related to this problem? I checked the sculpting shader but it is set to default, as for the rest of the model...
Can you share the project (PM?)
What if you bake any other default mesh (shift+M) just to test the procedure using another shader ?
I am reporting this as bug later, Multiply blend is not working for sculpt paint bake.
