Member giobianco Posted May 13, 2019 Member Report Share Posted May 13, 2019 Hi, I don't understand why in the preview the depth / normal of the material can be seen correctly, but when I apply it it is completely wrong.I have seen that the value of depth on the material is 15% while on the menu it is set to 100% ... bringing even that to 15% the depth is lower ... but it is always different from the previw. I am attaching two example images thanks for any replies and sorry for the bad english giobianco Quote Link to comment Share on other sites More sharing options...
Member giobianco Posted May 13, 2019 Author Member Report Share Posted May 13, 2019 I noticed that it happens when I use the "fill tool" with the options Layer, Surface, Object ,or if I use (always with the "fill tool") the lasso brush. If instead I use the fill tool by clicking on the surface, or using the tool brush the material is generated correctly (it comes as I see it in preview). Why is this happening? Help!! thanks Quote Link to comment Share on other sites More sharing options...
