Advanced Member blackant Master Posted August 1, 2019 Advanced Member Report Share Posted August 1, 2019 This is something i'm always complaining about since many years, it is the ability to see precisely the projection when you use the cylinder, sphere or box for materials box isn't really a problem cause it's everywhere the same projection as long as you don't start rotating it. but trying to use settings for cylinder is so hasardous because you can only see the result, so spending time searching wich value is the right one for X, Y and Z... so i made a montage in max just to explain what could be could. tell me if i'm wrong or not, but i think that if we can see the cage directly, we will not ask about any kind of parameter to set in. Quote Link to comment Share on other sites More sharing options...
