If I turn off close holes, it also works like it used to. Also, turning ngons off in Rhino did indeed fix the issue.
I saw the new close hole feature in 4.9.02 and started looking into that. Couldn't find a way to disable on import for voxelization, but you can when converting a surface layer to voxel.
Again, either way it works as it has going back to the 3.x days.
Posted by EricM,
0 reactions
Go to this post
