Member dimedius Posted January 28, 2020 Member Report Share Posted January 28, 2020 Not sure what happened but things were working earlier. I imported an object earlier and had the same tabs as before (mostly layers and blending etc). Now the only thing showing is vox tree. Is there a keybind i hit to disable this or what suggestions do you have? https://i.imgur.com/eeKrUge.png Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 28, 2020 Report Share Posted January 28, 2020 Hi Press Shift+M Select Paint UV Mapped Mesh Select the folder icon to load your model Quote Link to comment Share on other sites More sharing options...
Member dimedius Posted January 29, 2020 Author Member Report Share Posted January 29, 2020 I did that and the same thing happened. Quote Link to comment Share on other sites More sharing options...
Member dimedius Posted January 29, 2020 Author Member Report Share Posted January 29, 2020 Had some more time and found I could reset the windows to default and that solved my issue. Thanks! Not sure why it would've disappeared to begin with. 1 Quote Link to comment Share on other sites More sharing options...
