New Member corebreaker Posted March 10, 2020 New Member Report Share Posted March 10, 2020 Hey there. Im new to this program so maybe im just missing something if so just let me know Im running in to a problem where every time i hit the apply uv-set i get a crash. Im working on a model that was imported from zbrush as an fbx. made 4 UV sets and worked on each part. when i was happy with the unwarp crashes on apply UV-set any help would be great. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 10, 2020 Report Share Posted March 10, 2020 Hi Try applying this command before Retopo > remove n-gons Hope it help Quote Link to comment Share on other sites More sharing options...
New Member corebreaker Posted March 10, 2020 Author New Member Report Share Posted March 10, 2020 33 minutes ago, Carlosan said: Hi Try applying this command before Retopo > remove n-gons Hope it help Sorry, how do apply a command. step by step would be great. Quote Link to comment Share on other sites More sharing options...
New Member corebreaker Posted March 10, 2020 Author New Member Report Share Posted March 10, 2020 I think i got it. It was an ngon. did a retopo in 3dcoat that had an ngon in it. took it over to zbrush to add a few things then back to 3d coat for the UV unwarp. zbrush said it fixed the ngon when it was moved there but i guess it just goofed. looks like it works fine now thank you 1 Quote Link to comment Share on other sites More sharing options...
