Advanced Member nobackup Posted July 17, 2021 Advanced Member Report Share Posted July 17, 2021 (edited) Often merge subtree will just not work. It will do nothing, and then select a random layer in addition to the layer you are on. Or when it does work it, it also selects an additional layer for some reason. using 2021.06 edit: I think it has something to do with hotkeys, as it seems to work if you select it from the vox layer menu. However, using a hotkey produces buggy results. Edited July 17, 2021 by nobackup 1 Quote Link to comment Share on other sites More sharing options...
