New Member 3dbt Posted January 31, 2022 New Member Report Share Posted January 31, 2022 (edited) Hello, Everything is in the title. I have a 3d scan and i need to clean it, but impossible to import so far. It is a 1gb .ply, approx 55M polygons, nothing incredible for a 3d scan. I can open it in Gom Inspect. In Meshlab. In 3d scanner's software. The mesh represents a boat hull which is 10m long. 3dcoat doesnt want to import it sadly. I tried to import it as a reference. I have the last version 2021.61 I have 64gb ram, gtx1080 with 11gb of vram, Ryzen 5800x, SSDs with different partitions, 3 of them have paging file (parameters : automatic size). I just took a one month license to use 3dcoat a bit more, i used it once for cleaning a 3d scan of a sculpture and it was ok (less heavy though). I planned to use it more in my work because i saw and heard a lot of good things on it. Is this a known limitations of 3dcoat (like a particular way to import mesh or something) ? I can decimate the mesh without problem but my goal with 3dcoat, as i heard a lot of good things about its perf, was to work on raw meshes to keep maximum details and then doing the remeshing/decimating. Edited January 31, 2022 by 3dbt Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 31, 2022 Report Share Posted January 31, 2022 Hello Please drop a line to support@pilgway.com asking for this issue. Thanks Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 2, 2022 Report Share Posted February 2, 2022 Hello Please send us the model, so we could check it and detect the root of the problem. Thanks Quote Link to comment Share on other sites More sharing options...
New Member 3dbt Posted February 2, 2022 Author New Member Report Share Posted February 2, 2022 Hello, thank you, I send you a wetransfer link because my file is few mb above the upload limit 1 Quote Link to comment Share on other sites More sharing options...
