Member Florent-T Posted March 19, 2022 Member Share Posted March 19, 2022 Hi ! First, I have to say this is strange to post here this kind of question, regarding what's happening in Ukraine.... I feel... uncomfortable. But, should we stop using 3DCoat and making this alive ? I don't know... I'm starting to really go inside photogrammetry for reverse engineering, 3d printing... As you can see on the attached pictures (broken freezer handle, glued just for taking pictures), I'm now pretty happy with my raw scan results. But now, I have to clean all this. I know, the best here would be to measure it, and draw it with something like Fusion 360 I really know well. But it's not how I'll learn 3DCoat and its tools.... Also, you'll tell me to retopo it by hand, and I agree, even with 3DCoat or Blender, which I sometimes use... But again, I don't want to learn that for now. I want, here, to clean it by smoothing faces, sharpening edges, filling unnecessary cavities (this is a 2 parts handle, I'll 3Dprint it as a single simplified part), even cut the bottom parts and recreate resulted missing parts by copying (the new copy tool would do this, maybe)... Well, could you point me the right tools to use ? Or maybe a tutorial wich cover the needed tools ? Thanks you very much Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution Featured Comment AbnRanger Posted March 19, 2022 Reputable Contributor Solution Featured Comment Share Posted March 19, 2022 Try using the PLANE tool (maybe using 3 points to set the plane angle) and see if that helps. Quote Link to comment Share on other sites More sharing options...
Member Florent-T Posted March 20, 2022 Author Member Share Posted March 20, 2022 Thanks a lot ! That seems to do the perfect job. This and smooth/fill. I still need some pratice to find the tricks but it's the way ! I also still need to find where are the tools, as version are differents, but I'll :-) Thanks again 1 Quote Link to comment Share on other sites More sharing options...
Posted by AbnRanger,
0 reactions
Go to this post
