Member R2D5 Posted June 1, 2009 Member Report Share Posted June 1, 2009 Hello A "Draw Shapes on Surface" Tool simmilar to the "Draw with Splines" Tool would be cool. Im searching a oppertunity to draw a shape with a spline with atjustable points(like the "Draw with Splines" Tool ) but the shape i have drawn sahuld be filed(beveloed out) Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted June 1, 2009 Contributor Report Share Posted June 1, 2009 You can do that with voxel curves. They work a lot like "Draw with splines" but you can make filled closed curves (real solid shapes) to be added or substracted from the model. the hardness option doesn't work well it is the only problem when compared to "draw with splines" but you can simulate hardness by adding a point beside the points of the curve where you want to have a straight angle. Quote Link to comment Share on other sites More sharing options...
