Member Mr X Posted June 4, 2022 Member Report Share Posted June 4, 2022 I've had problems importing PLY files with vertex colour. So I tried downloading the newest released version and it still does not work. When I import a mesh in the sculpt room, the layer changes it's name to the mesh but no mesh is imported. It says it's 0 verts. OBJ imports fine. I've tried open the mesh in other programs and there's nothing wrong with it. What can I do? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 5, 2022 Report Share Posted June 5, 2022 Hi On import panel, is import w/voxelization turned ON ? Quote Link to comment Share on other sites More sharing options...
Member Mr X Posted June 5, 2022 Author Member Report Share Posted June 5, 2022 11 hours ago, Carlosan said: Hi On import panel, is import w/voxelization turned ON ? Yes, it gets auto checked if it's off when I import. But it does not matter if it's on or off. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 5, 2022 Report Share Posted June 5, 2022 Can you share the model to take a look ? Quote Link to comment Share on other sites More sharing options...
Member Mr X Posted June 5, 2022 Author Member Report Share Posted June 5, 2022 Here's an example mesh. https://www.dropbox.com/s/s70wi240rjfx2yo/mb3dxx_mesh.ply?dl=0 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 5, 2022 Report Share Posted June 5, 2022 Have you tried importing it into another application ? I tried to import it in 3DC and other applications but no mesh is imported. Quote Link to comment Share on other sites More sharing options...
Member Mr X Posted June 5, 2022 Author Member Report Share Posted June 5, 2022 Yes, it works in Meshlab and it should work in Windows 3d viewer and Zbrush. I don't have the last 2 so I can't verify that, but I've been told they work there too. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 5, 2022 Report Share Posted June 5, 2022 You are right, Meshlab open it without issues Export from Meshlab and importing again into 3DC load it without any troubles (mesh attached) Bug reported, thanks for point it up. mb3.zip Quote Link to comment Share on other sites More sharing options...
Member Mr X Posted June 5, 2022 Author Member Report Share Posted June 5, 2022 Cool, yes I tried importing your file and it worked. Quote Link to comment Share on other sites More sharing options...
