Carlosan Posted October 1, 2022 Report Share Posted October 1, 2022 Sketch tool allows you to create volumetric objects using x,y,z projections. White: Add geometry. Black: Subtract geometry. Ctrl + LMB: to paint black. Clear Current: Fill black, each axis separately. Fill Current: Fill white, each axis separately. Reset Sketch: Resets all axes to white, the cube is created again. Reference Image: Activate. Black and white image 256x256. You can ask me questions on the discord server here - https://discord.gg/a5TJyRA Discord community is great they actually often answer the questions that I just don't know about. Artstation: https://www.artstation.com/tenitsky Instagram: https://www.instagram.com/tenitskyart 3DCoat v2022.47 used Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 2, 2022 Author Report Share Posted October 2, 2022 3DCoat-2022-48 changes to Sketch tool - Possibility to operate bigger sketches (512*51*512), undo corrected. - Numerical input (via SPACE) works correctly for the Sketch tool. - Sketch tool, new functions: Hide gizmo, reset gizmo rotation - Sketch tool (hardsurface mode) become much much faster because it is no longer based on booleans. So it also become more stable. Also the curves over the edges may be automatically created to be used for additional post-processing (bevel, tubes, run brush etc). Quote Link to comment Share on other sites More sharing options...
