Adding scripts as menu items in 3DC 2022
kritskiy.001
Go to solution Solved by kritskiy.001,
Hello, I'm moving to 2022 and I'm trying to bring my scripts from V4 to 2022.
In V4 I would have a \ExtraMenuItems folder with a bunch of .xmls with MenuPath, MenuItem and Command tags to define the name, menu and the actual script that's going to be used when the command is selected.
I copied the folder to the \Documents\3DCoat\UserPrefs\Scripts\ExtraMenuItems\ and the scripts appear in 2022. However non of them works, I'm getting "Nothing was built in the module" error. If I run the script via Scripts > Run menu they work fine. Should I change anything for the scripts to work from the menus?
Thanks
1 hour ago, Carlosan said:
Hello
Better to ask Andrew.
I am shotting in the dark: try edit current room. I guess you have to add it to the text of the menu scripts.
Thanks, but it seems that editing the menu script won't help: there are no "commands" unless I'm missing something. Everything is being called via menu_item() function... Even the recent scripts list calls for a recent scripts menu item:
When you say "Better ask Andrew" do you mean by writing to his email? I imagine he gets 10000000 messages a day lol
Thanks
  • Solution
Ok got an answer from Andrew: the path in the .xml Command tag should be relative to the 3dc Prefs folder. In V4 it's
<Command>script:Scripts/ExtraMenuItems/scriptName.cpp</Command>
and in 2022 the prefs were moved deeper:
<Command>script:UserPrefs/Scripts/ExtraMenuItems/scriptName.cpp</Command>
Edited by kritskiy.001
