Member ghDude Posted June 14, 2009 Member Report Share Posted June 14, 2009 Still learning this software. 1) I dropped three separate primitives in the voxels tab "scene" and was wondering how to "select and delete" the unwanted object. The are all on the same layer. hiding still maintains the object. thanks Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 15, 2009 Reputable Contributor Report Share Posted June 15, 2009 Still learning this software. 1) I dropped three separate primitives in the voxels tab "scene" and was wondering how to "select and delete" the unwanted object. The are all on the same layer. hiding still maintains the object. thanks Yeah...this is not intuitive at all. We need better options to select an object and delete it. I tried right-clicking on the layer in the vox tree, and none of the objects are deleted after clicking "delete." Oh...once you click on something other than "Primitives," it will drop whatever you have hanging there. Very odd way of working, and not clear enough for people new to the program. Selecting and deleting should be as easy as pie, but it's not, currently.We need to not have any primitve appear unless you click in the viewport, and there needs to be a "Selection" tool (like in 3ds Max, Maya...etc), to where we can select in the viewport (not have to right click on a layer) and that object highlighted with transform gizmo...when we hit the delete button on the keyboard, it should do just that. Also the Vox Tree rollout perhaps should have a trash can icon at the bottom of the pallet (visible delete option) Quote Link to comment Share on other sites More sharing options...
Member VolumesculptR Posted June 15, 2009 Member Report Share Posted June 15, 2009 Agree. Should be placed in features request section ? Quote Link to comment Share on other sites More sharing options...
Advanced Member Oliver Thornton Posted June 16, 2009 Advanced Member Report Share Posted June 16, 2009 Still learning this software. 1) I dropped three separate primitives in the voxels tab "scene" and was wondering how to "select and delete" the unwanted object. The are all on the same layer. hiding still maintains the object. thanks The best way I have found for deleting large volumes in voxels with the current toolset is the primitive tool itself. If you hold down CTRL when you hit enter the primitive tool will work subtractively instead of adding voxels to the scene. You can 'cut' out unwanted objects or chunks quickly and easily with this. You can also use RMB options in the voxel tree to subtract one layer from another to get the same result. This will allow you to cut out fancy shapes instead of being restricted to the basic primitives and imported vox stamps. Cheers, -Oliver Quote Link to comment Share on other sites More sharing options...
Member ghDude Posted June 17, 2009 Author Member Report Share Posted June 17, 2009 The best way I have found for deleting large volumes in voxels with the current toolset is the primitive tool itself. If you hold down CTRL when you hit enter the primitive tool will work subtractively instead of adding voxels to the scene. You can 'cut' out unwanted objects or chunks quickly and easily with this. You can also use RMB options in the voxel tree to subtract one layer from another to get the same result. This will allow you to cut out fancy shapes instead of being restricted to the basic primitives and imported vox stamps.Cheers, -Oliver great.. it acts like a boolean .. thanks. Quote Link to comment Share on other sites More sharing options...
Advanced Member 3dioot Posted June 17, 2009 Advanced Member Report Share Posted June 17, 2009 Or you do it the easy way. Movie 3dioot Quote Link to comment Share on other sites More sharing options...
Member ghDude Posted June 18, 2009 Author Member Report Share Posted June 18, 2009 Or you do it the easy way.Movie 3dioot i'm starting to like it now... much easier!! thanks Quote Link to comment Share on other sites More sharing options...
