Member lexa123 Posted January 28, 2023 Member Report Share Posted January 28, 2023 I installed 3d coat from steam and it wrote acces problems and crashed could you help me please the error message Quote Link to comment Share on other sites More sharing options...
0 Carlosan Posted January 28, 2023 Report Share Posted January 28, 2023 Hi Try turning off One Drive Hope this help On 1/26/2022 at 1:40 PM, Siddhant Mishra said: Hello. Here is a quick fix how can we fix this error easily. Hope you find it useful.3D Coat Unable to write file(Quick Fix) Quote Link to comment Share on other sites More sharing options...
0 Member lexa123 Posted January 29, 2023 Author Member Report Share Posted January 29, 2023 23 hours ago, Carlosan said: Hi Try turning off One Drive Hope this help hi it is still doesnt work Quote Link to comment Share on other sites More sharing options...
0 Carlosan Posted January 29, 2023 Report Share Posted January 29, 2023 Is One Drive turned off ? Are you installing into the default location ? Quote Link to comment Share on other sites More sharing options...
0 Member lexa123 Posted January 30, 2023 Author Member Report Share Posted January 30, 2023 15 hours ago, Carlosan said: Is One Drive turned off ? Are you installing into the default location ? yes Quote Link to comment Share on other sites More sharing options...
0 Carlosan Posted January 30, 2023 Report Share Posted January 30, 2023 are you installing as administrator ? Quote Link to comment Share on other sites More sharing options...
0 Member lexa123 Posted January 31, 2023 Author Member Report Share Posted January 31, 2023 14 hours ago, Carlosan said: are you installing as administrator ? i installed from steam, so idk Quote Link to comment Share on other sites More sharing options...
0 Carlosan Posted January 31, 2023 Report Share Posted January 31, 2023 Just press RMB over the installer file .exe and select Run as Administrator If this step isnt working sorry, but i am out of ideas. Hope this help Quote Link to comment Share on other sites More sharing options...
0 Member lexa123 Posted January 31, 2023 Author Member Report Share Posted January 31, 2023 2 hours ago, Carlosan said: Just press RMB over the installer file .exe and select Run as Administrator If this step isnt working sorry, but i am out of ideas. Hope this help no it doesn't help at all it just crushing Quote Link to comment Share on other sites More sharing options...
0 Carlosan Posted January 31, 2023 Report Share Posted January 31, 2023 On 2/20/2023 at 3:27 AM, Refin_ken said: Startup error how to fix it? "3DCoat" is trying to create a user data folder (which contains user settings and assets) inside "C:\Users\USER_NAME\OneDrive\???????\3DCoat". That is incorrect. It should create it inside "C:\Users\USER_NAME\Documents\3DCoat". To workaround this problem: Start > start typing "Edit the system environment variables" > Environment Variables... > System variables > New... > Variable name: COAT_USER_PATH Variable value: C:\Users\USER_NAME\Documents\My3DCoatData (specify your user name inside) Quote Link to comment Share on other sites More sharing options...
Question
lexa123
the error message
9 answers to this question
