Advanced Member akira Posted June 24, 2009 Advanced Member Report Share Posted June 24, 2009 Currently when merging/importing poly meshes into voxel room, we cannot preview how many voxels will be created and how much memory will be needed for the conversion. Sometimes I overscaled my mesh and got a out-of-memory crash in return after hitting enter. Feature request: Show the current voxel density and memory requirement of the importing mesh base on the size of it's bounding box. So that we won't need to press and pray anymore. :P Regards, akira. Quote Link to comment Share on other sites More sharing options...
Advanced Member Ghostdog Posted June 26, 2009 Advanced Member Report Share Posted June 26, 2009 I think this is a really good idea. The more you use the software the more you learn the memory requirements, but sometimes a critical mistake is made is selecting too much subdivision upon import and you have a system lockup as it starts to run out of ram. It is not easy to force-quit the software even when you know its going to lock-up. I only have 32bit system with 2GB ram on a Vista laptop so memory issues occur quite frequently, it's fairly annoying when it's 'my fault' on settings used so I'd love to see an estimation made as Akira suggests. Quote Link to comment Share on other sites More sharing options...
