Advanced Member zf3d Posted October 8, 2023 Advanced Member Report Share Posted October 8, 2023 The brush and eraser are not working properly I don't know why, but after saving many versions, this version is no longer easy to use 笔刷不知道为什么不好使 00_00_05-00_00_51.mp4 Quote Link to comment Share on other sites More sharing options...
Advanced Member zf3d Posted October 8, 2023 Author Advanced Member Report Share Posted October 8, 2023 I seem to have found the reason, all the faces have been reversed Quote Link to comment Share on other sites More sharing options...
Advanced Member zf3d Posted October 8, 2023 Author Advanced Member Report Share Posted October 8, 2023 Tell me about my solution After my inspection, the model did not reverse But it is covered by inexplicable voxels, which makes the eraser difficult to use, but the area brush works well, and the back is hooked off to make it work I feel as if there is an invisible layer of voxel painting covering it So I moved all the models in the room where I was editing the geometry, and miraculously, all the colors dimmed a little bit Then I returned to the painting room and everything was normal 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 28, 2023 Report Share Posted December 28, 2023 May be you have View > Show voxels in Painting Room activated ? Next time try turning this command OFF Hope this help Quote Link to comment Share on other sites More sharing options...
