Member EvilMP Posted November 26, 2023 Member Report Share Posted November 26, 2023 Has anyone ever sculpted Dreadlocks or Hi Res hair in 3D coat. If so what brushes and process did you use. I can't seem to sculpt Dreadlocks I have tried the muscle tool, toothpaste, snake and spikes with no luck. The reason I am asking is because I was going to do a Predator sculpt but the hair keeps stopping me from finishing due to the dreadlock type hair they have. I have searched high and low and nothing on it or even a process on how to even get started on manually creating that type of hair in 3D coat. Quote Link to comment Share on other sites More sharing options...
Advanced Member gbball Posted November 26, 2023 Advanced Member Report Share Posted November 26, 2023 Make the base forms a little thinner than you want, then increase the resolution. Apply procedural noise and then extrude a bit. Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted November 26, 2023 Report Share Posted November 26, 2023 16 hours ago, EvilMP said: creating that type of hair in 3D coat Have you tried the Splines tab? You can use your model segment, drag it into the Splines tab and attach it to a Curve. Quote Link to comment Share on other sites More sharing options...
