Show Rotation angle when rotating with Gizmo
1. Please shows the rotation angle near the Gizmo, and enable user define snapping to certain integer, say 1, 3, 5 degree on pressing Shift or other key. I think shift has been assign to move gizmo only, maybe other key is needed.
2. Please also enable Gizmo to have 2 axis movement. like, XY, YZ, XZ.
Maybe this will help.
Hover over a Gizmo element------ hold down the LMB and hit the space bar then add your input. Make sure the Gizmo element is highlighted when holding down the LMB.
This might not entirely be what you need, if not put in a feature request.
Yes, this is one option. Just hope to have realtime display of degree
