Member rs3d Posted July 8, 2009 Member Report Share Posted July 8, 2009 When using very fine structures like "palm_leaves_segment.obj" with the Snake Tool almost no geometry appears in the Voxel object. The only solution I found is using a higher resolution, but some kind of Threshold for OBJ to Voxel conversion would be more useful. Is there a function like this hidden somewhere? Best, Rob Quote Link to comment Share on other sites More sharing options...
Javis Posted July 8, 2009 Report Share Posted July 8, 2009 You simply need to increase the resolution of the voxel layer to have finer details. If the resolution is not high enough, small details will not be created with such tools. Quote Link to comment Share on other sites More sharing options...
Member rs3d Posted July 9, 2009 Author Member Report Share Posted July 9, 2009 That's clear to me, but by looking at the results closely (and having worked with other voxel software before) I have the feeling that this could be solved with a "sampling threshold" allowing to create a voxel also when a geometry is not filling the voxel 100%... Best, Rob Quote Link to comment Share on other sites More sharing options...
