New Member J PHO Posted January 27 New Member Report Share Posted January 27 Hey guys, I'm trying to figure out how to undo smooth selection on a mesh I was manually retopoing. I was working in the retopo window, I applied a Smooth Selection CC on my mesh, and for some reason, I saved it after and when I opened it to find out the smooth has been applied on the mesh. Is there a way of undoing that? I can't seem to find anything on the subject. I'm using the latest version of 3D coat 2023.40. Thanks! Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution digman Posted January 27 Reputable Contributor Solution Report Share Posted January 27 I believe there is not. There is no undo history saved with the file, at least I do not think so. Only thing I can advise is to have AutoSave turned on in Preferences---General tab. If it was turned on which is on by default, load the last auto save or an earlier one. You set the timing of the auto saves and how may to save. I prefer this manual method. Incremental saving but that is a user's choice. Before any major operation, I can save an incremental file or just to be safe. The file will be saved under the folder location of your original 3DC file. Ctrl + Shift +S If you do not see your autosaves under the File menu----Open recent list, the files are located if using Windows, in the location shown in the picture. Quote Link to comment Share on other sites More sharing options...
New Member J PHO Posted January 27 Author New Member Report Share Posted January 27 That is unfortunate. Thank you for the help Dig. That would have been my next question if it was salvageable by autosave. I also do the same thing save before I make big changes to my project, but this was unwarranted. I'll keep the autosave option in mind. Thanks again! ^v^ Quote Link to comment Share on other sites More sharing options...
