Member sketcherdas Posted May 11, 2024 Member Share Posted May 11, 2024 When I draw textures, the camera accidentally rotates, is it possible to lock the current view while working? I would be very grateful to the community for their help. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 11, 2024 Share Posted May 11, 2024 If you take a closer look at toggles inside the Camera > Customize Navigation window, you'll notice that you can disable certain events. For camera rotation around a pick point or object, it can be NAVI_ZB or Rotate in Screen Space. 1 Quote Link to comment Share on other sites More sharing options...
Member sketcherdas Posted May 11, 2024 Author Member Share Posted May 11, 2024 5 minutes ago, Carlosan said: If you take a closer look at toggles inside the Customize Navigation window, you'll notice that you can disable certain events. For camera rotation around a pick point or object, it can be NAVI_ZB or Rotate in Screen Space. can you explain in a more understandable way? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 11, 2024 Share Posted May 11, 2024 I repost the link to Taros's video tutorial on " How to start to painting outside mesh borders" What that means is that you can start your paint stroke outside the mesh and when the stroke hits the mesh, the paint is applied... The object is not rotated. On 5/30/2017 at 12:49 PM, AbnRanger said: You could disable the NAVI ZONE at the very bottom of the Custom Navigation panel and you could disable the LMB action from rotating outside the object, by finding that LMB action in the panel and unchecking OUTSIDE THE OBJECT. This video shows how to setup a custom action, such as Trackball Rotation. You can get an idea how it works. If it works for you, make sure to save as a Preset, in that Panel. It's a button toward the top of the panel. Also, for future reference, you can have 3D Coat ZOOM EXTENTS/FRAME OBJECT in the Navigation bar, by clicking the ALL icon...or SHIFT + Z. Another option is to click the crossed out "O" icon, 2 spaces to the right, in the Navigation bar. That sets your navigation to the default camera view...as if you opened the app for the first time. Quote Link to comment Share on other sites More sharing options...
Member sketcherdas Posted May 12, 2024 Author Member Share Posted May 12, 2024 thank you all so much! 1 Quote Link to comment Share on other sites More sharing options...
