Advanced Member rimasson Posted August 3, 2009 Advanced Member Report Share Posted August 3, 2009 Is there an easy way to mirror a voxel model, when the symetry is lost ? Quote Link to comment Share on other sites More sharing options...
Javis Posted August 3, 2009 Report Share Posted August 3, 2009 if your symmetry plane is still at 0 along the X axis, all you need to do is use the Cut & Clone tool with symmetry turned on or off. If it's off, turn it on when you're done clicking and dragging with the C&C tool, it will also set you to the Merge tool. Once symmetry is activated with the merge tool, you have a few options here. You can create this new volume on the same layer as your copied information, or create a new layer. I opt for making a new layer almost every time. Then, you can simply use this new layer you have created with both sides symmetrical. Hope this helps. Quote Link to comment Share on other sites More sharing options...
