Member adamdaly Posted April 14, 2010 Member Report Share Posted April 14, 2010 Hi, i was wondering if there is any method to navigate the viewports easily within 3dcoat when using a stylus. I've up until now been using the buttons at the top but it would be much easier to do it in a similar way to zbrush. Adam Quote Link to comment Share on other sites More sharing options...
Contributor LJB Posted April 14, 2010 Contributor Report Share Posted April 14, 2010 Hi, i was wondering if there is any method to navigate the viewports easily within 3dcoat when using a stylus. I've up until now been using the buttons at the top but it would be much easier to do it in a similar way to zbrush. Adam You can, click on the camera tab in the right hand corner of the view, 3D coat setting will let you pan, dolly amd rotate the view based on free veiwport clicks, Left button or stylus equivalent will rotate middle will pan and right will dolly. But best to use Maya style which requires you to hold alt key and same buttons apply. - leigh Quote Link to comment Share on other sites More sharing options...
Advanced Member polyxo Posted April 14, 2010 Advanced Member Report Share Posted April 14, 2010 You can, click on the camera tab in the right hand corner of the view, 3D coat setting will let you pan, dolly amd rotate the view based on free veiwport clicks, Left button or stylus equivalent will rotate middle will pan and right will dolly. But best to use Maya style which requires you to hold alt key and same buttons apply. - leigh I think the default 3DC-scheme works pretty darn well with a stylus and offers a lot of functionality as also hovering over the Tablet while not touching is mapped with functionality (Pen Size/Depth). You should be able to perform all basic Camera-controls with the Stylus alone and the Pen-Button, no? I find one hardly ever has the Navigation-Buttons. The only thing I experience is that the Pan-Functionality of the Pen stops working from time to time, especially when changing rooms. Does anyone else see this? Quote Link to comment Share on other sites More sharing options...
Member adamdaly Posted April 14, 2010 Author Member Report Share Posted April 14, 2010 yup your right, now that i've fiqured it out the wacom integration is very good. Thanks for the replys. adam Quote Link to comment Share on other sites More sharing options...
