Member Phizter Posted September 23, 2011 Member Report Share Posted September 23, 2011 Hi Andrew, I think you should add an Apply symmetry to all visible layers feature in the Retopo room. And then the current Apply symmetry to all layers feature should be removed. I just lost a lot of work I did in the Retopo room. I was working on a group where I needed symmetry on both X and Z, so I frequently hit Retopo/Apply symmetry to the current layer in the drop-down menu as I was progressing. During this work, all other Retopo groups where hidden. At some point I must have antecedently hit Retopo/Apply symmetry to all layers. A fatal mistake I only realized way too late (after I saved the file). Now all my other Retopo groups were mirrored. Not exactly what I needed:(. Some time back we had a similar problem in the Voxels room, where it was possible to manipulate hidden layers. This is now fixed and it saves the users from a lot of trouble . I think You should make it a golden rule that layers and groups in 3D Coat cannot be manipulated as long as they are hidden. Finally I think it is a bit confusing that the text in the drop-down menu refers to layers when the tap above the retopo layers says Groups. As mentioned before I believe that 3D coat would benefit a lot from a terminology overhaul. Right now the terminology within 3D-Coat is a bit blurry and indecisive. Best regards -Martin Quote Link to comment Share on other sites More sharing options...
