3DCNC
3d base relief from 3d model - scam or possible
4 posts in this topic
I did this once for a Nike project, but it was not an easy process. This seem to suggest it could be
I have done something similar with Modo and ZBrush. With Modo You can project (background constraint) mesh to a original model (that have scaled in projection axes) and background plane. After projection detail transfer is simple. This is pretty straight forward process and result is almost same. I think this can also be done with 3D-Coat :)
Isn't this what the 3D-Coat Bas-Relief tool is for?
1 person likes this
Yes Phil. 3DC works fine.
As all these will probably be exported as normal or bump maps, I wonder... crazybump app could be a solution in lot of cases.
