Advanced Member alvordr Posted January 27, 2013 Advanced Member Report Share Posted January 27, 2013 I was working on a project overnight that turned out rather well after I manually retopo'd it. I was adding further details, afterwards to rebake, but had to go to sleep. I awoke to have 3DC crash. I tried to import my retopo mesh that I had exported from 3DC last night into the scene to reuse and found that it was considerably smaller than my Voxel sculpt. I've been trying to manually scale it back, but I'm finding myself having to spend a lot of time messing with this. Is there a shrink wrap function in 3DC that I don't know about? If so I could simply make it bigger than my Voxel and do it. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted January 28, 2013 Reputable Contributor Report Share Posted January 28, 2013 No shrinkwrap... Snap in the left too bar menu can snap the retopo mesh to the voxel or surface object. but the user still has lots of manual work to do as stated below... You still have to use the transform tool to resized and line up the retopo mesh so it is pretty close to where it needs to be. That is 95% of the work done by the user and snap finishes it off. If your retopo mesh is not very close to being correctly resized and aligned you will have vertices shooting off to where they do not belong when you click on snap... Quote Link to comment Share on other sites More sharing options...
