johnnycore
Merging Imported Multiple Normal Maps..
I have a model which is split up into multiple sub objects, all of them have their own UV's (ofcourse) and I have painted normal maps in 3d-coat but then the client decided he wants something changed to the model..
So I've exported the model als obj including maps, editted the model and reimported the models + textures and change uv's a bit. Everything is working fine still..
However theres one problem, I now have multiple layers with multiple depth info (normal maps)
Somehow I am NOT able to merge these layer to a single depth layer.. when I merge the layers, the depth info disappears.
I can still work like this but I was wondering if its possible to merge these layers to a single layer?
Also tried out "copy channel" which does not do anything..
i use for this:
texture export normal map
add new layer
texture import normal map
This is also what I do except I don create a new layer because it automatically gives me a new layer.
However, it does not merge the layers into one layer for me.. instead it just gives me 8 layers (one for each normal map)
I export all layers from
Textures
Export
Normal Map (TS_Low poly Mesh)
* TGA file format
then i delete all layers
add a new one
Textures
Import
Normal Map
all the maps are merge in one layer named Normalmap (ext)
Sorry, this is not what I meant exactly.. :)
My obj has 8 sub objects, so 8 UV sets.
When I export normal map I get 8 normal maps.
I have to import them one by one, which result in 8 layers.
However I found out how to merge them..
It seems when importing a normal map you get a layer with the blending mode "normal map", somehow I overlooked this I expected the normap map to be imported as depth.
