topology Symetry enhancement
rimasson
I would like to tweak a topology (created outside of 3D coat) in 3d Coat;
The only constraint i have is that i can't change the vertex order of this topology.
I imported a reference mesh.
entered the topology mode.
imported an external mesh
enabled the symetry across X
tweaked my model
my problem is :
if i disable the symetry, only 1 side of the model is tweaked.
If i apply the symetry, the vertex order change.
In a future version, could it be possible to tweak symetrically a topology or the low poly model ?
Understood. But vertex orrer could be same only if youuse vertices tweaking. Other oprations will add faces/verts.
It's ok for me.
Thanks a lot.
3D coat already help me a lot : when i import an external topo, the topo is automatically conformed to the reference model. It saves time.
I just have to symetrize the model in Silo.
