Instancing can take place when you import for Voxel sculpting or Surface sculpting. You have the most options for altering your instances when using the "Merge" tool.
While in the Voxel Room, choose "Merge" and navigate to the portion of the parameters panel that allows you to select your mesh for importing. You can also adjust the subdivision level and choose to place instances in the scene by means of the Transform gizmo or "On pen" (which allows you to "paint" your instances one at a time
Posted by Psmith,
0 reactions
Go to this post
