Member riuthamus Posted August 21, 2013 Member Report Share Posted August 21, 2013 (edited) Long story short, I created a low polygon model for use within our game. Most low polygon games dont use normal maps ( least that I knew of ) so I never thought to make them. We decided to try out a normal map and it looked amazing except for the seams. After doing some searching most game developers make a very high polygon mesh and then use that for the normal by baking it. My question is simple, can I use 3dcoat to create a voxelized version of my current low polygon. Sclupt in the details, and then bake that back down to the low polygon model? This is the current normal on the model: This is the current normal map ( using a 2d editor ) Edited August 21, 2013 by riuthamus Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted August 21, 2013 Reputable Contributor Report Share Posted August 21, 2013 Sure, that is a typical workflow in 3D Coat. These videos might help explain the workflow a bit... http://www.youtube.com/watch?v=839ZKEOeOAU&list=PLlQ3JITh9bXOfcZqGuO8gClZisN6yUd1x&index=16 http://www.youtube.com/watch?v=OYaojBQSrpg&list=PLlQ3JITh9bXOfcZqGuO8gClZisN6yUd1x http://www.youtube.com/watch?v=qJDNyLKGGaU&list=PL0614F2A03AD725CD&index=47 Quote Link to comment Share on other sites More sharing options...
Member riuthamus Posted August 21, 2013 Author Member Report Share Posted August 21, 2013 Thanks, those look like they might help alot! Quote Link to comment Share on other sites More sharing options...
Javis Posted August 22, 2013 Report Share Posted August 22, 2013 You could also just bring in your low poly model and paint your normal maps directly to the mesh, or any combination of voxel/poly sculpting and direct texture painting. Looking forward to hearing your experience and see your results (assuming you can share the results of course). Cheers. Quote Link to comment Share on other sites More sharing options...
