Advanced Member FreezeFrame Posted November 15, 2013 Advanced Member Report Share Posted November 15, 2013 Hello. I ran into a slight problem. When adding objects and merging them to a scene. Is it possible after merging two objects at the symmetry line to adjust their distance from the line after? It allows during placement. All I noticed was if they are separate instances only 1 can be moved at a time unless they are joined as one then they both move. Also I made a very slight mistake when I merged two objects to form as one. I must of had symmetry off or something because I noticed a slight out of symmetry mistake, somehow. Is it possible to make a mesh not symmetrized into one? It's no big problem and the slight mesh deformation won't affect animation at all. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted November 15, 2013 Reputable Contributor Report Share Posted November 15, 2013 If you do not mind as you said the minor mesh deformation, then under the voxel menu (top menu) select (Symm Copy). Before doing that use say the smooth tool at a depth of "0" and perform one mouse / pen click on the side you want copied to the other side. Quote Link to comment Share on other sites More sharing options...
Advanced Member FreezeFrame Posted November 16, 2013 Author Advanced Member Report Share Posted November 16, 2013 That worked well, thanks for the response! Quote Link to comment Share on other sites More sharing options...
