Can someone tell me how i auto uv map an object which currently has no uvs, on 3.7 i could just select the auto map finction but now ive no idea... by the way whenm i click the uv tab i cant see the model this may be a problem or it may be how its meant to be.
thanks
thanks
If you import the object into the Voxel Room, you won't have any UV's. If you import it into the Paint Room, in the Import Options dialog, there is an option for use UV Map or Auto-UV. It will be a drop list on the right hand side. I'm flying blind without any screen grabs (ALT + SHIFT + S) or screen recordings
Edited by AbnRanger
